Commercial Dish/Glass Washers.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Commercial Dish/Glass Washers.
  • #32375
    fasetester
    hi guys what is the differience between a commercial glasswasher and a dishwasher. are the same to work on do the block up the same heaters go open circuit short out ect thanks fasetester 🙂
    #234913
    fasetester
    Re: The Dishwasher Thread……..
    wel guys do any of you repair glasswashers. fasetester 🙂
    #234914
    Re: Commercial Dish/Glass Washers.
    Two heater circuits usually, Fase. Wash boiler in the bottom and an element in the tub. Soft water round here, so don’t get clagged boilers. Two varistats can cause problems. Most of the ones I see have burnt out wiring, so pretty easy to deal with.
    Seamy
    I do a few Classeq glasswashers, they retail around £1k so are worth doing repairs on.
    #234916
    fasetester
    seamy what do you find are common problums with them are the faults different from dishwashers. thanks fasetester 🙂
    #234917
    Seamy
    Addititive pumps for bringing in rinse aid & detergent getting bunged up.
    Normal stuff like spray arms blocked, outlet pumps blocked with broken glass, broken wires at heater, etc.
    Most are drain only but some are pumped to empty.
    Did modifications on a few to allow start immediately rather than wait for heat-up which can leave machines slow in busy times.
    All cables are clearly marked in loom & you just have to join 2 connections together, this info is in service sheet which comes with each machine.
    #234918
    spanner51
    fasetester wrote:hi guys what is the differience between a commercial glasswasher and a dishwasher. are the same to work on do the block up the same heaters go open circuit short out ect thanks fasetester 🙂
    Glasswashers are usually smaller than dishwahers, to fit under a bar, and they have round baskets which spin on a turntable. Dishwashers usually have a square plate rack. Apart from that they both have motors, pumps, and timers etc
