Re: commercial dishwasher
http://www.easicook.co.uk/DEXION/dexion … eparts.pdf
most commercial dishwashers have 2 heaters. one in the rinse boiler item 230083 and one in the wash tank 456015
the rinse boiler heats first and after its up to temp the stat 236043 switches on the tank heater. this continues to heat until temp is reached when stat 236042 switches it off
as the current to these heaters is quite large the stats do not directly control the heaters but switch contactors which are mounted in the top ( there are 4 of them 2 will be for the heaters )
since your fault is no heat you need to concentrate on the rinse tank as the wash tank heater will not work till this is up to temp. check contactor, heater and thermostats. there is also an overheat stat item 236039 check for closed circuit
hope this helps
