I have been to a Lamber Newscan DSP44 with a number of faults all of which I have repaired by this one. The bottom 2 spray arms won’t rotate during the wash. The pump is delivering water to the top arms ok. I have replaced the boss that the arms sit on with no change.
Any Ideas?
Impellor on pump could be missing blades,take circulation pump off check impellor and also have a look up the connected pipes,very often broken crockery,spoons will be in there,must be some sort of blockage.
Filter in base/sump needs to be checked,make sure it is clean,new landlords don’t usually have a clue about the daily maintenance required on these machines.
Thanks for that, Ill check.
I have noticed that when it fills from empty the top arm of the two spins with filling water pressure? Does that mean any thing or is that normal?
