Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Common Refrigerator Hints
- This topic has 8 replies, 7 voices, and was last updated 20 years, 5 months ago by
Dave_Conway.
October 19, 2005 at 10:38 pm #12690
Dave_Conway
ParticipantVT9’s will fit Lec fridges with an exposed evaporator, for wet wall use a VX0 which is basically the same but has a lower cut out temperature, this applies to Candy/Kelvinator as well, basically poor quality or underpowered compressors where the evaporator doesn’t get as cold as a better quality product.
October 19, 2005 at 10:39 pm #151040Dave_Conway
ParticipantRe: Common Refrigerator Hints
A top six thermostats suggestion:
VT9
VC1
VS5
VX0
VT93/VT3
VP4/VL4August 31, 2006 at 6:38 pm #151041waters
I use just ranco vt9 or masterparts ge stats.These can be adjusted.
August 31, 2006 at 6:48 pm #151042waters
Turning the inner screw anticlockwise if fridge is getting to cold ie kalvinators and clockwise to adjust to cut out colder.Experience tells me if they need any adjusting because i fit new stats to all fridges before i sell them.
February 24, 2007 at 11:40 am #151043lokring
i wouldnt change the calibrayion on anything if if goes up in flames your up the creek without a boat or a paddle!!!!!!!
March 17, 2009 at 10:15 am #151044TeeMyob
Dave_Conway wrote:A top six thermostats suggestion:
VT9
VC1
VS5
VX0
VT93/VT3
VP4/VL4I agree and would say that the above is a good selection of thermostat kits.
I recently priced a Miele thermostat for an undercounter fridge. £139+VAT!. VX0 went in instead, mind you had to pay £10 for that from Connect. Sure in the past I only paid £5 for them.
Trev
March 18, 2009 at 9:05 pm #151045boselecta
VT9
VC1
VS5
VX0
VT93/VT3
VP4/VL4
Any chance of a quick description of these stats else they are just numbers?. . .March 19, 2009 at 5:16 pm #151046dpr1974
I had this laying about, hope it helps.
Thermostat guide:
Fridge Thermostat: Ranco VF3,VL3: Universal
Ranco:
UNIVERSAL
Freezer/Ice cream cabinet: ‘No signal’Cold out -34c, Warm out -16.5c, Warm in -12c, capillary length 2000mm:
Fridge Thermostat: Ranco VS5,VL5: Universal
Ranco: Compares to Atea W6, Danfoss Kit 6 and Whirlpool WPLW6
UNIVERSAL
Freezers with signal:Cold out -34c, Warm out -16.5c, Warm in -12c. Signal operation cuts in 5c above cut in. Capillary length 2000mm
Fridge Thermostat: Ranco VT3,VT93: Universal
Ranco:
UNIVERSAL
Fridge Freezers with extra long capillary:Cold Out -26c, Warm Out -11c, Defrost Termination +3.5c* (*Constant cut in) Capillary Length 3000mm
Fridge Thermostat: Ranco VT9,VL9: Universal
Ranco: K59L1102002 K59 Compares to Atea W4, Danfoss Kit 3 and Whirlpool WPLW4
UNIVERSAL
Two door Fridge / freezers WITH automatic defrost:Cold out -26c, Warm out -11c, Defrost termination +3.5c* (*constant cut in). Capillary length 1200mm
Fridge Thermostat: Ranco VT9R
Ranco:
UNIVERSAL
Fridge/freezers with auto defrost. Where the original thermostat has an internal heating restrictor.Cold out -20c, Warm out -8c, Cold in +3.5c. Capillary length 1200mm
Fridge Thermostat: Ranco VTD9,VLD9: Universal
Ranco:
UNIVERSAL
Fridge/freezers with heat assisted defrost systems.The VT9D operates in a similar way to the VT9, giving a defrost on every switching cycle. The control is fitted with a SPDT (Changeover) switch, enabling the defrost assistence to be switched on during the defrost period.
The temperature setting range is -25.5c to -14c with a constant cut in at +5c
Fridge Thermostat: Ranco VXO: Universal,Candy,Kelvinator
Ranco:
UNIVERSAL
Larder Fridges
CANDY
Fridge Freezers:
KELVINATOR
Fridge Freezers:Larder fridges operates in a similar way to the VT9 thermostat giving a defrost on every cycle. However, the temperature range setting is higher than that of the VT9 in order to prevent over freezing of the cabinet:
Fridge Thermostat: – Ranco VC1 KIT
Ranco
Compressor refrigerator
Cold out –23C, Cold in-14C.40C, Warm in +20C Capollary length 1200mmFridge Thermostat: – Ranco VP4/VL4
Fridge “Push Button” Defrost Cold Out -25°C” Warm Out -10, 4°C” Warm In -4°C Defrost Termination +5, 5°C
September 5, 2009 at 1:03 am #151047paddyd99
great post dpr, many thanks.
