Compatible grill and hob plate regulator belling cook enter 130 WCH
Home Forums Public Support Forums Spare Parts Help Compatible grill and hob plate regulator belling cook enter 130 WCH
  • #95016
    John11
    have just bought ELE9181 regulator but the terminals are different how do I know where attach the wires
    #459093
    If you are replacing the old Diamond H type then you will find that
    Diamond H Regulator Conversion Chart
    John11
    Thank you for replying but is all Chinese to me I’m afraid – I have put all the terminals in the same appropriate places but there is a red S1 and a blue S2 wires that don’t have obvious (to me) terminals to go on
    #459095
    are you sure you have the correct regulator ?
    what is the numbers on the original regulator?
    John11
    Thank you Dave we managed to figure it out in the end and it is working. Excellent service thank you so much.kind regards
    #459097
    John11
    Well thought we’d fixed it but now the grill fan will not turn off . Could it be a terminal attached in the wrong place . Original regulator was 43ER101C1 5/02 we have fitted a comparable ELE9181 which does not have the same layout to transfer the terminals so it’s a bit hit and miss!
    #459098
    well you need to message the shop. when I research your original number I get a different regulator so you need to give them the full model of your cooker and the old regulator number to check if its compatible
    also what is the regulator controlling ? and is it single circuit or dual ( dual circuit is where you can turn the regulator left or right on say a grill. turn it one way and half the grill comes on but turn it the other all the grill comes on )
    dave
    #459099
    John11
    Hi Dave will do – it should be a dual grill but it is turning on all the grill. Thanks for your help I will message them to find out. kind regards john
