Compressor Alternative
  • #35011
    subs
    I need a compressor for this Lux made fridge freezer which the cust has imported from France. Mod ARF5299X. The compressor is a Lux made one, GVT75AA (R134A). Although i have not checked with the Lux group yet, i know the original will be expensive so am looking for a cheaper alternative.
    Subs
    #244780
    Dales-Electronic
    Re: Compressor Alternative
    Looks like its a fifth of a HP so you could use anthing with that size Aspera NB1116 etc, but to be sure I could do with the internal capacity in litres.
    #244781
    subs
    Dales-Electronic wrote:Looks like its a fifth of a HP so you could use anthing with that size Aspera NB1116 etc, but to be sure I could do with the internal capacity in litres.
    I was thinking myself about a 1/5 HP. Ill try and get the capacity. Spoke to Lux, apparently its Australian made, and they want £200 for compressor 😆
    Subs
    #244782
    Total volume is 470 litres.I havent got the cross over chart in my back pocket at the moment but the easy way to do it is as follows.
    under counter fridge / bottle cooler 1/8 R600a
    under counter freezer / square chest freezer 1/6 r600a
    upto 5′ fridge freezer or fridge 4′ chest freezers 1/5 R600a
    american or larger units 1/4 R600a
    Bryan
    #244783
    Dales-Electronic
    If Bryans capacity is right you will need to us a quarter of a hp bearing in mind it is a two door.
    On another point Bryan, whilst I appreciate that you retrofit R600a compressors (as I do too) to R134a systems (at our risk) it is not good practice to suggest this to others. In the case of Subs he could find himself in hot water if this repair goes wrong and the customer claims against him for both repair charges and loss of food. Or Milord he fitted an unapproved compressor to our Lux ff – guilty, £1K fine. 😡
    #244784
    Hi Dales
    The list doesnt mention retro fitting..lol. No advise given concerning cross overs,Just what calculations I use to choose the compressor size..
    Would I do that…nooo.
    Bryan
    #244785
    expertcat
    1/4hp r134a whirlpool part 481281729554
    #244786
    subs
    Thank you all for your input. Thanks also for your concern but ive replaced quite a few compressors now and done a few retrofits. I also explain to cust that opening system can sometimes create problems such as blockages which are difficult to remedy, so there is an element of risk involved. I told this cust that i would try and get him another brand of compressor as Lux one would be expensive and it only lasted 4 years anyway. He was morer than happy.
    Subs
    #244787
    spanner51
    Does any one use the Lokring system when fitting compressors?. Is it easy to use? Is it cost effective? I have been told not to braze connections on R134a systems, as it is potentcialy explosive.
    #244788
    Brazing R134a explosive !! absolute cods wallop…He doesnt know what he’s talking about…
    Brazing R134a is NOT explosive and is safe to do .
    Bryan
