Home › Forums › General Trade Forum › Condensation in back of van
- This topic has 11 replies, 10 voices, and was last updated 16 years, 1 month ago by
cornwell40.
February 10, 2010 at 10:55 am #52376
cornwell40
ParticipantThis year has been the worst I’ve ever known. Can’t look into my top bins without getting my head wet. My carbon brush bags are dripping wet (thank god for plastic bags), and the roof looks like a rainforest waiting to happen. Any good VIZ style tips on beating the condensation…..and please no space heaters 😉
TCFebruary 10, 2010 at 11:49 am #311556chalky
ParticipantRe: Condensation in back of van
how about putting a de-humidifier on an extension lead overnight? (or an inverter 😆 )
if its got a proper air con unit wont that dry the air?February 10, 2010 at 12:31 pm #311557Phidom
I have a dehumidifier I bought to keep my classic motorcycles dry in the garage but it’s hopeless in cold weather as it needs an ambient temperature of at least 10 degrees. My van is the same with condensation. I had frost on the dashboard one morning.
February 10, 2010 at 1:25 pm #311558leavemetogetonwithit
Maybe you could stick a VTD00P in the back and run it on a timeswitch for a short period without a load. It should draw in air from the van and dry it. ❓ 😆
Mike.February 10, 2010 at 2:25 pm #311559timdowning
http://www.hardware-ironmongers.com/details.aspx?code=3500044
Just googled condensation absorbers.
February 10, 2010 at 3:50 pm #311560iadom
ModeratorRe: Condensation in back of van
Used to use those when I had a touring caravan, they did work but you had to keep draining and refilling them.
Some thin sheets of polystyrene foam stuck to the roof would do the trick.
Don’t think they sell indoor polystyrene roof tiles now but it may still be available in thin sheets.
February 10, 2010 at 4:04 pm #311561don
Why not try your local electrical retailer for some discarded polystyrene sheets, Beko refrigeration among others use thin sheets of the stuff.
Don
February 10, 2010 at 4:16 pm #311562Gazman1000
It’s due to a lack of air circulation moist air gets trapped and condensation forms on any cold surface, do you have a sealed bulkhead behind the drivers seat? My van had the same problem only after the bulkhead was fitted.
The only cure is to cover the cold roof panel with insulation I used an old carpet off cut and glued it to the inside of the roof, you could fit a spinning roof vent like they fit on police dog vans, that would expel any moisture in the air as the van is driven.February 10, 2010 at 10:15 pm #311563admin
KeymasterRe: Condensation in back of van
ply line the van out……?
dont get any probs….in my van.
canufixitFebruary 10, 2010 at 10:19 pm #311564cornwell40
Mmmmmm condensation or lack of sleep. I’ll stick with the water ta 😉
TC
February 10, 2010 at 10:24 pm #311565cornwell40
I’ll try the carpet Gazman :waving: , but the spinning police dogs will have to wait. 😉
TC
February 21, 2010 at 3:36 pm #311566bigchrisoioi
you could try putting the roof up on your convertible van!!! 😀
