Condenser dryer by hot point
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Condenser dryer by hot point
  • #80062
    mistructe
    Started to trip mains when running but only runs short time with finger on start button ! Any ideas and suggestions appreciated
    #411530
    Re: Condenser dryer by hot point
    Hows THIS for an idea to start with. 😉
    #411531
    mistructe
    Ctd00
    #411532
    Possibly two faults, tripping due to heater being damp, this is caused by a failure to clean the condensor properly and at regular intervals. Can often be cured by drying out the heating element with a hairdryer and giving the condensor and its housing a good clean. Pay particular attention to the very back of the condensor chamber, there is a groove along the back that gets clogged with gunge.
    Having to hold start button in suggests a possible relay fault.
    #411533
    mistructe
    Thanks will check it out this weekend
    #411534
    mistructe
    Have changed the heater element but now operating only when holding start button down which eventually blows mains fuse so is this a timer dial switch problem and how do I check what needs to be replaced?
    #411535
    suggests a relay fault but it shouldn’t blow a fuse. Is it actually blowing a fuse or just tripping the circuit breaker?
    Either way the whole of the machine needs testing for insulation faults with a megger.
    #411536
    mistructe
    Thanks for replying – just tripping the main circuit breaker breaker when start button held down too long
    #411537
    As i have already said, it needs a relay but it still should not trip so it still needs a megger running over it.
