condenser dryer tc71 not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum condenser dryer tc71 not heating
  • #30709
    jasper
    hi guys out there in appliance land, got a problem with
    hotpoint condenser dryer, model, TC71, ULTIMA.
    NO HEAT,!! checked the usual ie, stats ok!, heater ok ! continuity checked ok,! even changed the main timer switch??.
    pullin ma hair oot!!!
    any constructive solutions oot there.
    much appreciated
    jasper
    #228124
    helo_75
    exhaust stat? only thing left
    open the door, look upwards, there it is.. screws, pull it out gently…
    plug out, for sure
    #228125
    richardable
    Re: condenser dryer tc71 not heating
    be gentle when you pull the stat out, ive known the two wires to be very very short and they can spring back out of sight 😉
    richard
    #228126
    There is also a reversing timer in the base that does fail causing no heat fault.
    Kathy7777
    Hi I had the same problem the drier was turning and blowing air but was cold. To fit the drier it was either the thermostats or the heater element. The thermostats are green spot and were £3:50 for two and the heater element was anywhere from £40:00 to £96:00 so I just replaced the thermostats. I thought it was worth a try for £3:50. Put the new ones on and it started to heat the air straight away. I would advise anyone to try just changing the thermostats first before spending money on heater element that you might not need.
    #228128
    The original post is 10 years old, and the thermostats are mentioned in the original and subsequent posts. 🙁
