Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Condenser Tumble Dryer Decision.
- This topic has 12 replies, 6 voices, and was last updated 15 years, 9 months ago by
Sensemaya.
July 8, 2010 at 6:24 pm #55737
Sensemaya
ParticipantHello
I’m so pleased the forums are back in business. Special thanks to KWatt on MSE.
Anyway I’ve got a problem.
Started new post on MSE.
http://forums.moneysavingexpert.com/sho … ?t=2581669
I would be extremely grateful if one of you kind Sirs would advise me on what to get.
Cannot afford the ISE or a Miele and hopefully I will have the money saved up by September.
Thank you.
July 8, 2010 at 8:45 pm #324960helo_75
Participanthard to advise, but for most, zanussi tend to be a quality product for reasonable money
dont buy a hotpoint, loads of problems for the price they are
btw, your machine probably just needs a relay.. the dryer itself is better than any hotpoint machine you can buy these days.
July 8, 2010 at 9:10 pm #324961aqualectric
ParticipantRe: Condenser Tumble Dryer Decision.
It’s an easy fix – the door release relay has failed. They are about £20-25 + fitting. Much, much cheaper than a new drier. The drier will run for 5 minutes then stop. Leave it for a few minutes for the relay to cool down and try again. A quick test is to hold the start button in when it stops. The drier will run as long as you hold in the start switch. This is not the repair solution and wedging the start switch is not recommended. New relay ASAP.
It dismays me to see how some members of the public ( as in 2 replies on MSE) say, “Bin it…..it’s a throw away world” and “A new drier is more efficient” shows just how uninformed some people are who give “advice”. Advice should be given by persons with the necessary knowledge to do so. To scrap machines without researching if they can be saved is not only disasterous for the environment, but foolish and wasteful. Your Crusader is a Creda / Hotpoint in a dress and back then built in Britain to a reasonable standard. They haven’t got any better I can assure you…..
Most driers in the £250 – £300 bracket will be scrapped after 3-4 years so any energy efficiency savings and environmental considerations will pale into insignificance when the chap at the scrapyard starts up the crusher….. 😉
I have a Hotpoint drier in my workshop as we speak that is 14 months old with a drum that has collapsed through the plastic bearings and worn the back bearing shaft until it sheared off. This is mid range quality stuff. Imagine what the cheap ones are like……..You say you cannot afford a Miele or ISE so Bosch is the next mark down. Anything else is…..well….let’s just say you’ll be posting on here regularly. :rolls:
A.
July 8, 2010 at 9:28 pm #324962iadom
ModeratorRe: Condenser Tumble Dryer Decision.
A little mystified by that statement, apart from a few hours here and there due to server problems we haven’t been away AFAIK.
Have to agree with most of the above although Zanussi washing machines do seem to have become very troublesome and expensive to repair their tumble dryers are quite decent and as a lot of Bosch dryers are ‘bought in’ from Gorenje and the like, buying a Gorenje in the first place would be a cheaper option.
I would personally go for a Zanussi dryer over the current Bosch machines if I didn’t have a dryer but would most definitely have your current dryer repaired without question. 8)
July 9, 2010 at 5:51 am #324963Sensemaya
Thank you to everyone.
I’m sure KWatt mentioned quite awhile back that he had to stop people posting but I must have got confused. Sorry about that.
An engineer has phoned me back – same firm that fixed thermosat 3 years ago, didn’t want to come out to make sure he was right and said it was definitely a timer problem and would cost approx £95 to fix. Said I should scrap it because it was 10 years old and not worth fixing.
I will do what aqualectric suggests and post back later today. I totally agree with you about repairing rather than binning.
Thanks again.
Edit:Tried it. It stpped and when I pressed the Start button nothing happened. Left it a couple of mins, worked again and just as it was about to stop I caught it in time and it does appear to be working. So that is it I hope.
I am going to PM helo_75.
Thanks guys.
July 9, 2010 at 9:10 am #324964iadom
It may be your username, we have been flooded with spammers for a long time now and some usernames do cause the odd ‘itchy finger’ on the ban button. 😀
July 9, 2010 at 6:08 pm #324965Sensemaya
Hi iadom
I only registered on here yesterday although I have browsed the site for years.
Hoping helo might come out to fix it as he lives not too far from me. Fingers crossed.
Thanks again for everyone’s kind help. You have all saved me loads of money.
July 9, 2010 at 8:07 pm #324966bosch-engineer
Hi iadom, I can asure you Bosch no longer buy in badged machines from Gorenje. All the Bosch dryers are now made in a Bosch factory! 😀
July 9, 2010 at 9:14 pm #324967iadom
bosch-engineer wrote:Hi iadom, I can asure you Bosch no longer buy in badged machines from Gorenje. All the Bosch dryers are now made in a Bosch factory! 😀
Thats the situation at the moment, but for how long, and where is this ‘Bosch’ factory, China ? 😉
July 9, 2010 at 10:17 pm #324968helo_75
Participantu got a pm, bev 😉
July 10, 2010 at 8:51 am #324969bosch-engineer
Hi iodom, there are about 40 BSH group factories world wide. Take your pick! All the top end stuff come out of factories in Germany. IMO pound for pound, I would choose a Bosch dryer every time. Pay a little bit extra & get a much better machine. 😀
July 10, 2010 at 9:08 am #324970admin
KeymasterRe: Condenser Tumble Dryer Decision.
But they are still on sale..spares for the bosch badges are 5 times more expensive than the original Gorenje ones because they come in a packet saying Bosch not gorenje.
Bryan
July 10, 2010 at 4:44 pm #324971helo_75
bosch-engineer wrote:Hi iodom, there are about 40 BSH group factories world wide. Take your pick! All the top end stuff come out of factories in Germany. IMO pound for pound, I would choose a Bosch dryer every time. Pay a little bit extra & get a much better machine. 😀
what utter nonsense…. u tryin to wind ppl up or summert?
