Condensing Vs. Vented Dryers
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Condensing Vs. Vented Dryers
  • #6844
    rjrichmond
    Hi, I’m looking to buy a dryer for the first time and just wondered what the difference is and which is the better option?
    #119876
    Dave_Conway
    Re: Condensing Vs. Vented Dryers
    If you can easily site a vented one and vent it correctly these are the better option.
    They are more reliable and more efficient.
    If you do have to go for a condenser, go for a decent one 😉
    #119877
    rjrichmond
    Dave_Conway wrote:If you can easily site a vented one and vent it correctly these are the better option.
    Thanks – I want to put it in an understairs cupboard – how do you vent them?
    #119878
    Dave_Conway
    rjrichmond wrote: Thanks – I want to put it in an understairs cupboard – how do you vent them?
    You won’t be able to unless the wall behind it is an outside one, the vent needs to go outside.
    It sounds like you need a condenser, these don’t need venting as they self condense the water, you just have to empty the water container at the end of every cycle.
    Go for a Bosch, Siemens or Miele.
    #119879
    rjrichmond
    Dave_Conway wrote:You won’t be able to unless the wall behind it is an outside one, the vent needs to go outside.
    It does back on to an outside wall but assume we’d have to knock a hole in the wall?
    #119880
    rjrichmond wrote: It does back on to an outside wall but assume we’d have to knock a hole in the wall?
    Yes you would using a ‘Thru the wall vent kit’ and flexi vent hose between the two 🙂
