Configuring
Viewing 15 posts - 1 through 15 (of 17 total)
  • #93264
    revned123
    Please let me know how to configure the control module for ZWF1640W Zanussi washing machine?
    #453722
    Re: Configuring
    first question Why?
    the module is supplied by the manufacturer in configured and unconfigured as new. you need specialist software to programme it yourself
    revned123
    Re: Configuring
    It’s displaying E90.
    #453724
    revned123
    Re: Configuring
    electrofix wrote:first question Why?
    It’s displaying E90 with all the lights flashing.
    #453725
    Re: Configuring
    there are a number of E90 faults. you are seeing the customers display number but it fall into a couple of categories
    I would try the following. find the cables that go between the main board and the display board on the front panel. remove and replace the cable twice to make sure the contacts are clean. be careful putting too much pressure on the wires to the plus as I have had them come out. Do this on both ends of the lead especially where it connects to the display panel as that is where I have had problems myself
    if that fails to work then it looks like one of the boards may be faulty and needs replacing
    revned123
    Re: Configuring
    I never did connect this board to the washing machine. I bought it some ago and put it away to keep a spare one. Now that the control PCB on my washing machine is not working at all, I thought that I could replace the faulty board with this one.
    What could other faults be related to E90?
    #453727
    Re: Configuring
    in that case I would say the board you have bought is incompatible with the display board on your machine. If you had the production number of the machine the donor board came off we could check if its correct
    in the old days if the timer looked correct it would probably work but these days you can have the same board with different software on machines with the same model. When I looked up your model I found there are 6 of them and there might well be more than 1 software version in those 6
    revned123
    Re: Configuring
    I do not know which machine the other board is for.
    Below are the three numbers on the label which is stuck on the heatsink of the motor triac:
    Type P. 451527007
    Type E. 132225524
    SW Ver. W4A30127
    #453729
    Re: Configuring
    unfortunately that does not mean anything as they use the same board and
    re-programme for different models.
    what happened to old board ?
    revned123
    Re: Configuring
    The old PCB kept displaying E50. I replaced the motor triac but that it didn’t help.
    #453731
    Re: Configuring
    the e50 series of faults is not just 1 fault
    e51 motor triac
    yes can be motor triac can also be motor with a slight short to earth through either condensation, carbon dust or a motor failure
    e52 no tacho signal from motor
    mean the motor is not turning could be brushes
    e53 motor triac sensing faulty
    this can also appear from motor earth fault or board fault
    e54 motor relay contacts sticking
    which speaks for itself
    all you will see is E50 unless you go into diagnostic mode so it could be any of the above
    revned123
    Re: Configuring
    The motor is a brand new genuine Zanussi one which I bought not so long ago.
    I think I need a new board and they’re very expensive. Could something be done with the other one displaying E90?
    #453733
    bazza500
    Re: Configuring
    I would be tempted to check the motor wires where they enter the motor plug by giving them a tug one at a time. Had a few where the wire breaks inside the insulation.
    #453734
    revned123
    Re: Configuring
    I checked and double checked the wiring harness that goes from the control board to the motor several times. What about my new control module that is displaying E90, can it be re-programmed to replace the old one?
    #453735
    Re: Configuring
    only by the manufacturer
