constructa vibration
  • #34952
    baridan5
    hi everybody
    i have a problem
    i replace a bearings in constructa open from up
    you can choose spin 500 or 800 rpm
    i dont know the model
    its open only from the side of the belt wheel
    in the spin the machoine has vibration very hard
    i replace the shox and its continue
    what can i do more ?
    the costumer wants to kill me !!!
    please help me thanks everybody
    #244570
    aqualectric
    Re: constructa vibration
    Are the concrete weights loose? They will make a terrible hammering noise on spin.
    Worth a look!!
    Steve.
    #244571
    Sounds like a Philips top loader type from the description.
    Have you checked for loose balance weights? Or loose motor mounts? Or is it just on a bouncy (wooden?) floor? Or it could be drum shaft fracture I suppose.
    Mike.
    #244572
    baridan5
    someone told me that its the seal between the door and tub
    its too much hard and its a known problem in that machine
    i will try a new one and tell you
    #244573
    baridan5
    so i replace the seat between the door to the tub
    and now the machine is great
    i heard this problem is known in germany machine .
    thanks everybody
    #244574
    Just a thought for the future, Baridan. Your machines have different names and model numbers which we may not recognise. A picture will help us to help you.
