Continue water inflow
  • #83413
    garethrwalsh
    I have a Servis washing machine. When switched off there is still water coming into the machine. The only way I can stop it is by turning off the stock cock to the washing machine. Any ideas as to what it could be and how to fix it.
    #422708
    don
    Re: Continue water inflow
    Model number would help 😉
    Sounds like like you have a faulty inlet valve(s)
    Don
    #422709
    garethrwalsh
    Its an M6713.
    #422710
    Andy jones
    Yep faulty valve
    #422711
    don
    You have a hot and a cold fill valve, you just need to identify which one is faulty.
    Dave in the shop should be able to supply either for you. Send an email to him at spares@whitegoods.co.uk he will be able to sort for you.
    Valves are just under the lid on the end of the fill hose 😉
    Don
    #422712
    garethrwalsh
    Thanks for all your help, the part is on order and I will let you know what happens. Going to try fitting it myself (first time for everything).
