Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Control Module – SGS 6312 GB/13
- This topic has 3 replies, 3 voices, and was last updated 18 years, 8 months ago by
paul384.
August 28, 2007 at 12:28 pm #30092
paul384
ParticipantThis module was replaced under warranty about 6 years ago and has, like others I’ve read about on here, blown the connections on the heater relay pins. It looks in quite a bad way but I will have a go at re-soldering. The heating element seems to be insulated and has an internal resistance of 23 ohms.
My questions to the vastly more knowledgeable experts here are:
1) Is there any other component which may have contributed to this failure that I should check before repair/replacement?
2) The single-digit display is absolutely dark – does this suggest (as I think I read somewhere on here) that the circuit board is totally u/s?
3) Can this board be sourced separately or only within the module?Must add that this forum is a wonderful resource – thanks to all concerned in maintaining it.
August 28, 2007 at 6:59 pm #225874Penguin45
ParticipantRe: Control Module – SGS 6312 GB/13
1/ Relay pins burn out due to an inadequate joint.
2/ Display should come on regardless of heat status – there may be other damage.
3/ The module is supplied as both boards, in the plastic case. £106 plus the usuals last time I checked.Got to be worth soldering it up and seeing what happens…….
Penguin45.September 2, 2007 at 12:13 pm #225875paul384
2 blown joints on relay re-soldered plus another which looked iffy. 2 tracks had also blown, one leading to the relay, the other on the power input to the board (maybe the reason for the display being dead?). Bridged the tracks, but still no life when re-assembled.
£130 for new module or add another £200 or so for a new machine with an extra 10 years-worth of development which should be more economical and efficient? If the module were only £60ish it might be different, but I think I’m heading to Curry’s. 🙁
September 2, 2007 at 4:21 pm #225876iadom
ModeratorRe: Control Module – SGS 6312 GB/13
paul384 wrote:
£130 for new module or add another £200 or so for a new machine with an extra 10 years-worth of development which should be more economical and efficient? (
Thats the theory, in reality, efficiency is often sacrificed for economy. :rolls:
