Converting old Zanussi part numbers to new Electrolux
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Converting old Zanussi part numbers to new Electrolux
  • #51431
    Poppins
    Hi Folks,
    Does anyone know how to convert the old Zanussi 6 digit part numbers into the new Electrolux 11 digit number please?
    I understand there is a logic to it…or is there? 😕
    Cheers
    Chris
    #308033
    rogue_element
    Re: Converting old Zanussi part numbers to new Electrolux
    whats your part number ??
    #308034
    aqualectric
    Try putting 889 or 899 before it….. that sometimes works. 😉
    Steve.
    #308035
    Naah – that’s the old AEG numbers. You had to put 645 after them as well. 5006 used to work for the Zanussi ones.
    Poppins
    Thanks for that Chris, I did try the 5006 as that often worked for me before but it doesn’t this time.
    It’s definitely not AEG Aqualectric as its a lovely old Zanussi Z918T when they were proper Zanussi’s. It’s the bearings and seals I am after. The original part numbers were 061479, 061408, 095515, and 061783. The whole set could be bought under part number 097387.
    Chris
    #308037
    rogue_element
    50097387000 bearing assy
    put 500 in fount of part number & 00 at end
    #308038
    Poppins
    Thanks for that Rogue-element. You meant 50 at the front and 000 at the end. Showing the full number helped. I’ve just priced it with Connect at £126.86 plus VAT. Pretty expensive it seems. I’m going to try the individual part numbers the same way and see how that goes.
    Much appreciated
    Chris
    #308039
    rogue_element
    no prob `s
    happy to have helped
    rogue
    #308040
    Poppins
    Actually …you’re a star rogue-element.
    I didn’t have any success with using the same sequence with the other part numbers but I have managed to find out that it is the same as an FL814 and all the conversion numbers are shown for that showing the very same old numbers and their new equivalent.
    Brilliant.
    Cheers
    #308041
    Alex
    If you use 344783014 that is the complete bearing and seal kit in a blister pack. Connections price trade around £11 or £12 + vat.
    Alex
    #308042
    Poppins
    Hi Alex,
    Thanks for that. In fact, now that I have had a chance to compare the updated part numbers it turns out I already have the correct bearings in stock.
    Cheers anyway.
    Chris
    #308043
    Poppins
    Hi Guys,
    For information I thought you might like to know that the 26 year old Zanussi Z918T lives on. I changed the bearings on it last weekend and it has been used daily since. So one delighted customer who has her beloved Zanussi going again and one contented engineer. 😀
    Thanks for all of the help received.
    Chris
