Cooker circuit open all the time?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cooker circuit open all the time?
  • #56561
    shalimar
    I have a Tricity Viscount electric cooker. One hob did not work. I assumed the electric ring was broken and therefore replaced it. The hob still did not work.
    I therefore checked the circuit with a tester and got a circiut reading both when the switch was turned off and also when the switch was turned on (i.e an open circuit both ways).
    I tested the circuits of the other hobs that were working correctly and when they were switched off I got no circuit reading. When they were switched on I got a circuit reading.
    On the broken hob; I get a circuit reading when both off and on. Why is this?
    When I look at the back of the dials there is no visible sign of damage to any dials including the suspect one.
    Any help much appreciated?
    #327957
    clivejameson
    Re: Cooker circuit open all the time?
    The simmerstat is faulty…if you post up the model number of the cooker, or the type number of the simmerstat then we can advise you which replacement you require 😉
    #327958
    shalimar
    Clive,
    Thank you for your reply.
    The simmerstat is:-
    SUNVIC SIMMERSTAT 2
    TYPE TYJ6202 (O B)
    200/250V ONLY
    50E
    Kind regards,
    Shalimar
    #327959
    clivejameson
    This is what you need….
    #327960
    shalimar
    Clive,
    Thank you very much for your help. Much appreciated.
    Kind Regards,
    Shalimar
