cooker cuts out – ROSIERES model PG100IN 35904127
Home Forums Public Support Forums Help And Support Cooker And Oven Forum cooker cuts out – ROSIERES model PG100IN 35904127
  • #80246
    coppers123
    hi i have a ROSIERES cooker model PG100IN 35904127 and when i switch it on it either won’t turn on or if it does it cuts out.
    after numerous attempts to start it will eventually start and stay on for a bit and then will cut out.
    sometimes if i keep fingers crossed it will stay on and cook a meal.
    any suggestions as to what is the problem – is it a loose connection in the electrics or do i need to replace the electrics, and if yes can you get the part.
    thanks
    #412231
    Re: cooker cuts out – ROSIERES model PG100IN 35904127
    So you’ve got a 5 burner dual fuel range cooker.
    There isn’t a lot that can cause this. You are mentioning it cuts out then stays on. The model that you have supplied is a electric oven.
    Do you mean the gas hob doesn’t stay lit ?.
    What is the serial number for your cooker. there will be 18 digits long 35904127 ????????
    Bryan
    #412232
    coppers123
    its the electric cooker that won’t work properly. sometimes it won’t turn on, sometimes it won’t stay on and turns itself off. sometimes it will stay on and cook a meal!
    normally when i turn the oven selector knob the light flashes, and it may stay on or it will just turn off. and the same happens when i turn temperature knob.
    http://www.adepem.com/IMG_APPAREILS/PG1 … SIERES.jpg
    #412233
    It could be the switch assembly,clock ass,thermal cut out but there is a break in the model so the serial number will be needed.
    The majority of the spares are still available.
    Where about in the country are you ?
    Bryan
    #412234
    coppers123
    bryan you sound like you are my saviour. i am in southend on sea essex. where do i get the model number from
    #412235
    coppers123
    model number [found it in drawer] is 03590412704360110
    #412236
    coppers123
    Bryan thank you for repairing my Rosieres cooker. excellent customer service. i can highly recommend him and his company ffrservices.co.uk
