tr/ben cooker si450 the oven gets to about 150 and a thermal cut out at the back of the oven knocks the power off ,stat light stays on, it will only come on after it cooled down, iam thinking the stats letting it get to hot, its not the therm cut out, anyone had this problem
cheers paul
Dopper, is the COOLING FAN running, not the circulation fan inside the oven?
I’ve found that if the cooling fan fails or is running slowly this fault will occur! There is a stat (no) that comes in when cavity gets to a certain temp it will keep fan running on for a while until temp falls again. If fan doesn’t come on there is (normally) a high temp cutout that cuts off , to prevent fire.
