Cooker door washers
  • #86637
    Burtado
    Hello all,
    Got a Lofra oven – bought prior to them going bump in the uk.
    The handle has Fallen off it and, from what I can tell it is attached via some washers on the inside of the door, and a screw in the handle . My plan it to replace the washers which have misshapen and hopefully avoid a big bill or a new cooker. My question is do I need to buy special heat resistant washers or will simple metal ones do the trick?
    Thanks in advance!
    #432438
    Re: Cooker door washers
    Simple metal should be fine.
    Burtado
    Thanks! Managed to get it fixed, thanks for your help
