Cooker fan not working help!!!!!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cooker fan not working help!!!!!
  • #31819
    maxkd
    HI Guys the fan on my cooker is not working but everything else seems to be ok,is this a simple problem to fix?What normally causes this do i need to replace the fan?I know problems vary but just wondered what the most common reasons are to look for i do have electrical skills but i am not necesarily a cooker expert!
    Any help much appreciated!
    max
    #232614
    Hi Max,
    If it’s the fan then it’s likely the fan motor that’s failed.
    If it’s no heat then it’s likely the fan element that’s gone.
    A model number and make would help us help you.
    maxkd
    Re: Cooker fan not working help!!!!!
    Thanks kwatt,its actually just the fan but there is heat so presumably its just the fan motor then yes? or is there an individual fuse that feeds it they may of blown?are the fan motors normally easy to change?
    Anyway ill get the model no. to help the diagnosis
    Cheers
    MAX
