Cant answer that. have looked around but cant find any informatin on an error ur 09
you have a Cheap turkish made cooker. That makes getting technical info rather difficult.
you would need to strip the cooker and look at the clock, from what i can see the clock is probably this one
https://shop.ukwhitegoods.co.uk/20820140-cooker-and-oven-digital-clock
but you need to check
if it is then possibly changing the clock may cure it
the only chance i have of possibly getting info is to get the rest of the info off the cooker
there is a very long number that vesel use to identify the unit
