Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › cooker hood cpp 9ss
- This topic has 12 replies, 2 voices, and was last updated 7 years ago by
tash.
April 6, 2019 at 5:41 pm #95720
tash
Participantthis hood doesn’t have brand on it but i need a transformer to run 2 12v lights. i got one off ebay but it only run 1 light of course. the model comes up on connect but is an out of stock item and expensive. thanks
April 6, 2019 at 6:52 pm #461146electrofix
ModeratorBrand seems to be CDA
why does the transformer you have not run both lamps ?
what wattage are the lamps ?
April 6, 2019 at 10:33 pm #461147tash
Participantit’s 30w transformer i got not sure the wattage of 12v bulbs but connected together just dim flashing bulbs.
April 6, 2019 at 10:36 pm #461148tash
Participant- 0W DC 12V 2.5A LED Transformer
- Input Voltage: 100-240V
- Output voltage: DC 12V 2.5A
April 7, 2019 at 12:27 am #461149electrofix
Moderator30w is never going to be enough. expect lamps to be at least 20w each so you need at least a 40va transformer
there are lots around with outputs around 100va which is lots to spare
your overloading the transformer and its shutting down. in fact its an electronic transformer if it was a normal transformer it would just overheat
April 7, 2019 at 8:24 am #461150tash
Participantok dave cheers do you have any other information on the correct transformer for that . that’s for your help
April 7, 2019 at 9:06 am #461151electrofix
Moderatorno
since it seems to be CDA you could ring them and see if they still supply a spare for it. It may be dearhad one recently transformer from manufacturer £80 similar transformer of Amazon £15
have you still got the old transformer ?
April 7, 2019 at 10:06 am #461152electrofix
ModeratorI need to be able to read what is on the top of it clearly
can you try and upload a better pic or is the forum stopping you
April 7, 2019 at 10:15 am #461153tash
Participantyes said original was too large so took a screen shot
April 7, 2019 at 10:32 am #461154electrofix
Moderatorwill pm you my email send it to me
April 7, 2019 at 12:03 pm #461155electrofix
Moderatornothing special really got 2 possible answers
or
depends on whether you can put both cables in one end
also check lamps are correct size should be 20w each as these lamps are available in bigger sizes and they still fit so overload transformers
April 7, 2019 at 4:22 pm #461156tash
Participantthanks for your help
April 13, 2019 at 8:25 pm #461157tash
Participantfitted first transformer all good thanks
