cooker hoods
  • #52741
    adv
    ust to look am some off these. ie bulb blown . an nocking owt 3 amp fuse which was above easily to get too with ladders or chair.been to cuple lately stainlees steel type. ie whirpool.akr676/o1 1x cant find bloody supply to it any were 😆 help lads
    #312927
    trotter
    Re: cooker hoods
    Jeez……english would be good!
    I am guessing this is a chimney hood? If so then the supply is normaly located behind the “Chimney”
    #312928
    adv
    Re: cooker hoods
    scottish mate, yep a hood its all plasterd in tho. surely you dont have to break it all off? madness?
    #312929
    trotter
    Re: cooker hoods
    well aye! ah divntnah if this is the case wiv this ‘un
    sorry slipped in a bit of geordie ‘ish
    If there is no sign of cable either side then my guess is it will be behind the chimney, only other though is that they may have put it above the ceiling although unlikely I HAVE seen it done!
    #312930
    chezza
    Re: cooker hoods
    Can this really be a serious question ?
    #312931
    martinm
    Re: cooker hoods
    http://www.whirlpool.co.za/app.cnt/whr/ … odid/46262
    Yes the supply is normally behind the chimney duct, should be two screws at top of this duct near ceiling and then it sholud come off, unless your unlucky and they have run a shelf and cornice across it
    #312932
    Re: cooker hoods
    chezza wrote:Can this really be a serious question ?
    I think chezza is trying to say what most of us are thinking: Every house is different and the plug/switch fuse could be anywhere! I have had them under the floorboards in the bedroom above the kitchen in the past. You can normaly slide the chimney up or down or remove it to get inside without removing the hood but it all depends on the instalation.
    #312933
    adv
    Re: cooker hoods
    yep they have run cornish round it. took two srews off top part of duct slides down cant see any cables. the rest off it plasterd an fitted in with wood what a joke 😳
