Cooker main cable
  • #72604
    mbdas
    Hi ,
    Just a question been to a oven today where electrician has fitted 1.5mm 13amp cable with plug only when he pushed it back its sat on the cable and melted it causing dead short . The oven is 2.2kw so I know the cable and fuse sizes are ok but I thought the cable had to be heat resistant and to British standards rated. Does anyone know what the right cable is ? Is it H07? 😕
    Thanks mark
    #385031
    Re: Cooker main cable
    1.5mm 3 core heat resistant is good up to 16amps.
    #385032
    Seamy
    Refer to the manufacturer installation instructions.
    #385033
    mbdas
    No installation instruction,the cooker has been in for a couple of years so I think I will go with 1.5mm 3 core H07
