Cooker wire
  • #52446
    spanner51
    Can anyone tell me if this :-
    http://www.farnell.com/datasheets/36383.pdf
    is suitable for cooker internal wiring
    Graham
    #311823
    spanner51
    Re: Cooker wire
    I’ll take that as a no
    #311824
    BobHope
    Re: Cooker wire
    Hi Spanner51,
    the cable should be ok for build in single ovens and possibly double ovens but if in the main supply from the terminal connector it should be at least 1.25 mm.
    Bob.
    #311825
    spanner51
    Re: Cooker wire
    Thanks Bob
    I also found this
    http://www.farnell.com/datasheets/419152.pdf
    which I am going to order as it goes up to 12amps
    graham
    #311826
    BobHope
    Re: Cooker wire
    looking at the data sheet the 1.5mm will be fine for the supply and the 1 mm for the other internal wiring.
    Bob.
