Home › Forums › Public Support Forums › Spare Parts Help › “cookers” 600206 element 76×3719 required urgently
- This topic has 28 replies, 4 voices, and was last updated 21 years, 5 months ago by
admin.
November 11, 2004 at 9:30 pm #6789
KeymasterHi
im looking for a replacement element for the Bernstein groups (in administration) branded “cookers” fan-assisted oven
Had one replaced before under guarantee by caremark and the bag has the following details.FSE12VAN To replace V/S used on 632
xfer no: 27014
Part no: 76×3719
description: resistor 2000w 230vI understand this 76×3719 is the same part used in proline EF6200w ovens
ive tried sparesrus but they seem to be offline for ordering.
Ive read here that it may be possible to use a 3 turn Homark element as a replacement as it lasts longer. If so canany one guide me to the the correct part to order as the ones i have found seem to be 2500w 240v.
Will this cause a problem or are they ok to use.
all help appreciatedthanks 😆
November 11, 2004 at 10:36 pm #119584kwatt
KeymasterHiya,
Thay element is actually made, or supplied at least, on Elco Brandt built appliances and it was out of stock for a bit not so long ago but I haven’t checked it in a while.
Dave should be able to sort you one out in the morning without any trouble.
November 11, 2004 at 11:28 pm #119585admin
Keymasterkwatt wrote:Hiya,
thanks
i did read a post from about jan time that they were used on brandt and it was from there that i got the proline info.
thanks for now 🙂
November 12, 2004 at 9:28 am #119586Dave_Conway
ParticipantRe:
If you don’t mind a bit of adaptation, the Ariston one will fit which you can get from the shop here:
http://shop.ukwhitegoods.co.uk/2040-coo … an-element
Or I can get the original Brandt one in a few days for you at £30.43 inc VAT and post etc.
The 3 turn one on sparesrus won’t fit physically, it’s for different Homark models and the wattage is 500w more.
November 12, 2004 at 9:59 am #119587admin
KeymasterRe:
Dave_Conway wrote:If you don’t mind a bit of adaptation, the Ariston one will fit which you can get from the shop here:
is there much difference with the ariston in terms of fitting ? or is it just non original that is the difference?if it requires modification to the fitting Is the proline one a more suitable replacement ?
on a seperate issue i dont seem to be able to view the forums/ post when i am logged in – any suggestionsNovember 12, 2004 at 10:37 am #119588Dave_Conway
ParticipantRe: “cookers” 600206 element 76×3719 required urge
mwl not logged in wrote:is there much difference with the ariston in terms of fitting ? or is it just non original that is the difference?
Only the two main fixings from memory, they are in the same place and the element is the same size but the original has threaded holes and the Ariston one doesn’t, normally just a case of fixing it with a nut and bolt.
mwl not logged in wrote:on a seperate issue i dont seem to be able to view the forums/ post when i am logged in – any suggestions
Not using AOL are you ?
November 12, 2004 at 11:33 am #119589admin
KeymasterRe: “cookers” 600206 element 76×3719 required urge
Dave_Conway wrote:
Only the two main fixings from memory, they are in the same place and the element is the same size but the original has threaded holes and the Ariston one doesn’t, normally just a case of fixing it with a nut and bolt.Mmm might be tricky for might be easier with the original. is the proline not suitable then ?
Dave_Conway wrote:Not using AOL are you ?
nope
both access from work and home presents the same problem.
when i click on forums it just goes to a page saying forum information.when i log out and access it i can see these pages ?! 😯 😕
November 12, 2004 at 11:51 am #119590kwatt
mwl NLI wrote:nope
We’ve now had this from AOL (which is no great shock ;)) and two people not on AOL but not a slew of errors that I’d expect.
I use the site with IE6 as well as Mozilla extensively and have no issues at all on four PC’s using two different ISP’s and I cannot re-create the error. I have also tried going back through several versions of IE in an attempt to find out why this happens and the short answer is I can’t. I have also done some scanning on support forums et all and even they don’t shed any light.
The only thing I can assume it is would have to be some sort of firewall issue, ISP issue or a settings issue within the browser being used as if it were not then, as I said, I’d have slews of people telling me the same thing. 😕
Not a lot of help I know, but as I cannot isolate the problem or see the cause I can’t put it right.
November 12, 2004 at 12:37 pm #119591Dave_Conway
ParticipantRe:
There’s the log in question answered then 😉
I have added the Proline/Homark element to the shop now:
http://shop.ukwhitegoods.co.uk/2300-coo … an-element
Hope that helps.
November 12, 2004 at 12:55 pm #119592admin
KeymasterRe:
Dave_Conway wrote:There’s the log in question answered then 😉
Hope that helps.
ordering now thanks
re: the log in both home and work using IE6 with different isp
onyl similar factor may be the use of Norton Internet security firewall ❓ill try disconnecting the firewall at home ( can do this at work) and try it then and let you know
thanks for all the help
November 17, 2004 at 8:01 pm #119593admin
KeymasterRe:
Hope that helps.
Hi i got this part today but… its completely different to the one that i have ❓
the bag also says it is 2000w (which is the rating of my previous one ) but the unit says it is 2100w 240vhere are photos of my exisitng one <img src="http://www.mrwhitelabel.f2s.com/Picture{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}200011.JPG[img]
not the pin at the end which goes into the cooker
and the new one sent
[img]http://www.mrwhitelabel.f2s.com/Picture{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}200012.JPG” alt=”” class=”bbcode-img”>how do i go about sorting this out ?
November 17, 2004 at 8:03 pm #119594admin
first picture is here sorry 😳
note the pin at the end which goes into the cooker
November 17, 2004 at 10:49 pm #119595Dave_Conway
I think I know which one you need, I’ve had the same problem before with these Brandt made cookers.
Send them both to me at the return address on the label stuck to the packaging.
I’ll then send the correct one back to you after I’ve physically matched it up.
November 18, 2004 at 1:15 am #119596admin
Dave_Conway wrote:I think I know which one you need, I’ve had the same problem before with these Brandt made cookers.
ok thanks 😀
November 23, 2004 at 9:20 pm #119597admin
hi any luck matching it up ? -
