Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Cookers BDW060/A Dishwasher Not heating.
- This topic has 8 replies, 6 voices, and was last updated 19 years, 9 months ago by
Twoten.
July 10, 2006 at 2:31 pm #19043
Twoten
ParticipantCookers Dishwasher….is that a contradiction?
Customer complains this machine is not heating or drying.
I have checked the element and that tests out OK. I have put the appliance into test mode by pressing the select button 5 times but when i try to select appropriate test for heating the program seams to come out of the test mode.
Any ideas would be appreciated,
Thanks,
Keith.
July 11, 2006 at 10:10 pm #181489eastlmark
ModeratorRe: Cookers BDW060/A Dishwasher Not heating.
Looks as though none of us know this one in that guise, any idea who makes it?
July 11, 2006 at 10:21 pm #181490gegsy
ParticipantRe: Cookers BDW060/A Dishwasher Not heating.
Don’t know if this helps http://www.white-westinghouse.co.uk/spreadsheets/cookers/BDW060{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20Dishwasher.htm
July 12, 2006 at 1:34 pm #181491Twoten
The appliance wasn’t badged, all it had was a model number and a rating plate that said made in France.
Following a search I found the White Westinghouse with website the picture as Gegsy’s link shows.
I can only assume it’s manufactured by White Westinghouse. The wash pump is the ‘Askol’ style as used in some of the Whirlpools but mounted ‘across’ the back rather than facing the sump, the element is the cylinder style, again similar to that used by Whirlpool.
The front panel is the plastic type like the Diplomat held by 2 screws at the top corners and then unclips from the bottom. The control board is mounted directly behind this panel mounted vertically just clipped top and bottom in front of the element.
Can anybody spread any more light on this one?
July 12, 2006 at 2:05 pm #181492Dave_Conway
Found it ! 😀
It’s a Brandt made for PAB.
Wiring diagram on the way shortly, if you need part numbers let me know.
July 12, 2006 at 3:05 pm #181493Twoten
Thanks for the help,
Now the machine has been identified as Brandt does anyone have any ideas what would prevent it from heating?
This machine is only just about a year old. Element checks out OK. No sign of any damage on the PCB.
Customer says machine shows no error lights come on just the end light fails to come on and the water will not heat and dishes do not dry.
I can get into the test program (5 presses of the start button but then pressing the start button to step through the tests it just drops out of test mode (I am not holding the button down for for 2 seconds to cancel).
July 12, 2006 at 3:32 pm #181494Twoten
Thanks for the drawing, any ideas on my last post?
January 26, 2009 at 9:03 pm #181495dena89
I have one of these, customer said no heat.
When I tried it, motor shudders for about 30 secs then cuts out.
guesses its one of those plaset types.
any idea on cost?January 26, 2009 at 10:23 pm #181496Penguin45
Motor p/no 32X3326, £54 from Masterpart.
