Cookers single oven – Fan works, no heat no light
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cookers single oven – Fan works, no heat no light
  • #36460
    Doc_Lenny
    Think I need a new oven but it is worth a try to see if anybody can help with a possible repair. Model Number 603205.
    When switching the oven on red and amber indicator lights usually come on along with the oven light but they fail to show any signs of life 😥
    The clock works and the fan operates when the dial is turned to a fan function. I have had the heating element out at the back of the oven and the circuit has tested OK. The oven temp control knob clicks (as if calling for heat) as normal when I turn it.
    The oven was on when it failed. during which there was 2 blips in the power supply, not sure if it is connected at all but nothing tripped.
    Thanks for any help.
    #251083
    helo_75
    a make would be helpful?
    #251084
    Doc_Lenny
    helo_75 wrote:a make would be helpful?
    Sorry, It’s in the title “Cookers”, made by Nardi I believe.
    #251085
    Doc_Lenny
    Re: Cookers single oven – Fan works, no heat no light
    Just to let you know that I located the problem, maybe you can help with a spare part.
    The plastic controller (behind the function control knob) did not work properly as a small bit of plastic had broken off the spindle. This resulted in one of the contacts being damaged and thus no connection was being made.
    Spare part anyone??
    #251086
    Selector switch – p/no 040899009909R.
    An email to spares@ukwhitegoods.co.uk for prices and ordering.
    Doc_Lenny
    Thanks, emailed info and await reply.
