Cookology Cooker Hood Light
Home Forums Public Support Forums Help And Support Other Appliances Cookology Cooker Hood Light
  • #97991
    Mike69
    I have read all your stuff about the
    brand
    Cookology but would still like to ask a question.
    We have a Cookology CH900BK hood and the light is not very bright. I want to connect up another light to the circuit but I can’t find out what voltage the light is and whether it is AC or DC.
    The instruction manual (such as it is) says
    the isolated low voltage circuit board control, (12v AC input) makes the lights safer
    , but looking up the bulb specs it says the bulb is a DBS-2.5/65-H-120/33 which appears to be a 220-240v AC LED bulb.
    I bought some 12v LED strip/ribbon lights and they just went flash for a millisecond and then dead.
    Does anyone have any ideas or knowledge that might help me?
    Thank you
    Mike
    #470471
    lamp specs are
    • ILCOS D code for this lamp is: DBS2.5/65H120/33LED modules rectangle lamp Max wattage: 2.5 W Voltage range: AC 220240V Dimensions:
    so its a 240v led module. its also a max wattage of 2.5W
    that also means you cant uprate or add lamps to the circuit without damage
    Mike69
    Hmmm… that’s a shame, but thank you for taking the time to reply, Dave.
    Cheers
    Mike
