Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › cookworks dishwasher
- This topic has 23 replies, 10 voices, and was last updated 19 years, 3 months ago by
yvonne.
December 28, 2007 at 8:07 pm #198132
ParticipantRe: cookworks dishwasher
First action on start should be the drain pump running for about 30 seconds. When it stops, then you should get fill.
If that description sounds correct, it’s more likely that you have a fill problem – trapped/kinked fill hose, water off or valve failure.
December 28, 2007 at 10:25 pm #198133mmick26
thank you for your reply,would this be a easy fix for a complete novice.If not any idea what a repair man would charge to sort it
cheers
December 29, 2007 at 12:45 am #198134Penguin45
Difficult to call – these machines are notoriously fickle, so actually nailing the fault in the first place can be a problem. Water on and hose run is easy enough – valve function involves a resistance check, but access is awkward due to the construction of the rear casing.
If you’re not sure, a repairer will charge for an hours’ work, plus the part if it’s the valve. Discuss the rate when you make the phone call to avoid surprises.
December 29, 2007 at 3:40 pm #198135mmick26
ok thank you for your help
January 15, 2008 at 11:43 am #198136gottaheadache
i bought one of these machines as well – less than a year old and playing up big time
runs the first part of the cycle normally
moves onto second part of cycle, drops the dishwasher tablet, then stops dead
when i open it up, the plates etc are wet from the first part of the cycle, but the tablet is virtually dry – seems like no water in second part of cycle
it happens on all settings
sometimes it’ll do this, sometimes it’ll run normally – very hit and miss and getting to be a real pain
any clues what it could be? would it be something simple like a blocked filter ???August 2, 2009 at 8:32 pm #198137weejohn
hello all, I posted a manual here recently and unfortunately the file sharing site has deleted it – can anyone who has a copy of the manual post it somewhere for others to use?
Ta
August 2, 2009 at 9:54 pm #198138iadom
ModeratorRe: cookworks dishwasher
Sadly,your ‘recently’ doesn’t match what I would call recently. 😉
Dec 2007 to be precise. 🙂 It could even have been deleted as it may have been considered copyright material at the time.
August 2, 2009 at 10:13 pm #198139weejohn
it was deleted because i was unable to login to the fileshare site to keep it active – not because of copyright
August 3, 2009 at 8:44 am #198140iadom
Fair enough. 🙂
