This very modest-sized microwave has developed a simple fault. The door should be held closed by the two plastic hooks, mounted on a sprung slider inside the door opening edge. Without the spring’s downward force, the door catch neither holds the door shut, nor (happily) operates the safety microswitches.
Seems a shame to dump an otherwise functional cooker, but I’ve drawn a blank searching for a replacement spring. NOTE, I’m very aware of the stringent requirements when working on a microwave door, and have a microwave “leak” detector to verify a good electromagmentic seal after repair.
Grateful for any suggestions re a spring supplier, though I fear the recycling centre probably beckons…
