Cooling fan thermostat?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cooling fan thermostat?
  • #97619
    Parki10
    Cooling fan – Does it have its own thermostat?
    Hello – we have a smeg range style electric cooker. 2 ovens, grill and 5 gas hobs. Yesterday the electrics tripped while the oven was on (with quite a load bang from the oven!!) and when we put the electrics back on both ovens were still working, and their fans but when you turned them off the cooling fan was not coming on. This was the case for both ovens. is this the whole cooling fan unit? is it just the thermostat? Not sure because the cooling fan does come on with the oven. Can you help?
    #468664
    kaibart
    We will need the all important model number off cooker this can either be found on the back of the cooker or if you pull the both flap down there may be a sticker with model number on
    #468665
    Parki10
    Hi – i cant find a serial number anywhere on the front and we have to dismantle a cupboard to get it out which we would only rather do when we are changing a part. It is 3 years old, Smeg oven model number BM93BL – does this help?
    #468666
    well this is one of those faults where its strip it and see. when cooling motors go it very unusual to get a big bang so you will have to inspect every component.
    could be
    terminal block, wire rubbed through, Thermostat for the coolinf fan, Fan motor etc
    Parki10
    Is it easy to tell if it is the thermostat for the cooling fan because the cooling fan is still working when you turn the ovens on but it goes straight off when you turn the ovens off?
    #468668
    i would turn off power and take the back of and look to see if you see any problems. i assume the fan comes on when you turn the knob but there will be a stat or a timer board that will keep it going after switch off
    Parki10
    Thank you Dave – much appreciated, I will take it apart on the weekend and see if I can see the Thermostat or timer board. Will it be easy to see if the thoermostat isnt working? bernt out or something?
    #468670
    kaibart
    These are the 1st things I would check as these toc ( terminal overload cutout) are the most common fault on these oven
    #468671
    Parki10
    Thank you so much – tomorrow is pull out the oven and see. Watch this space !!!!
