Cooling fans
  • #4888
    ChrisR
    Hi everybody.
    Can anyone help!
    I need a cooling fan assembly (main oven) for a Atag OD4 53 ASE ser.9H4 14 OPO OOOO QOO 22 129.
    This is the squareish black box above the cavity.
    I also need a cooling fan assy(top oven) for a Leisure Rangemaster 90D.
    The two look identical but there may be some moulding differences.
    Are Leisure and Atag building for each other?.
    Electrue want over £100.00 trade for the Leisure fan on part number FVLT 3901000.
    Any advice gratefully received.
    Thanks Chris.
    #105983
    Dave_Conway
    Chris, I phoned Aga (who now own the old Leisure Rangemaster name).
    The fan motor is quite a bit cheaper from them, if you phone them on 0870 7895106 they should be able to supply you at trade price, if not let me know, I can order it for you.
    I can’t help with the Atag one unfortunately, but it would not be unreasonable to assume it is the same motor, if you order the Leisure one you can check then I guess.
    BTW Connect have zero stock of the motor, Aga have, and they are pretty speedy generally.
    HTH
