corbero LD1450
  • #52791
    spanishwhite
    The above machine has the following symptoms,
    Programme selected-the machine will start, water fills and the machine will start to wash.However approx 15 mins into the wash the machine then starts drawing more water into it until it overflows.By moving the selector forward the machine will continue with no further problems.
    The pressure chamber has two hoses going to the pressure switch.The hoses and chamber are clear.
    PNC 914240808
    Have i missed the obvious?
    #313137
    spanishwhite
    Re: corbero LD1450
    #313138
    Re: corbero LD1450
    What sort of machine is it?
    We often don’t see any info on machines sold out the territory that we happen to be in, even under a brand sold in the UK or any other country. It’s a real pain at times.
    Pictures are good as they are often either much the same as models sold in the UK or just a variant of one sold here. The PNC would indicate it’s an Electrolux Group produced machine.
    Also, if there are any of the guys on from Spain, it just comes down to whether they notice the thread or not. 😉
    If it’s a washing machine though, it sounds like a pressure switch failure.
    HTH
    spanishwhite
    Re: corbero LD1450
    Sorry kwatt,didn’t make it clear in my first posting.It is a washing machine and as you correctly stated they are part of the Electrolux group.
    Steve
