Home › Forums › Public Support Forums › Spare Parts Help › Correct replacement door lock for Hotpoint Aquarius+ FDF784?
- This topic has 6 replies, 2 voices, and was last updated 13 years, 7 months ago by
G7MRV.
August 25, 2012 at 6:47 pm #71143
G7MRV
ParticipantThis evening the door catch/lock has failed on our Hotpoint dishwasher. Its an Aquarius+ FDF784. The spring has sheared off.
I cant seem to see a correct replacement listed. The door lock mechanism part no. C00094128 looks almost identical, except that the microswitch on this one accepts a modular plug, whereas the spare part has spade terminals.
Can anyone direct me to the correct mechanism spare part please?
If C00094128 is physically correct save for the microswitch connection, i can swap the microswitches easily enough
August 25, 2012 at 8:25 pm #380134iadom
ModeratorRe: Correct replacement door lock for Hotpoint Aquarius+ FDF
There are three different door latches fitted to these machines. You should make sure you fit the correct one, at least one has a low voltage switch and fitting the wrong one would lead to other damage.
You need to provide us with the full serial number and any other numbers from the rating plate which is usually down the inside edge of the inner door.
August 25, 2012 at 9:08 pm #380135G7MRV
ParticipantRe: Correct replacement door lock for Hotpoint Aquarius+ FDF
Thanks iadom,
this one has a 12v microswitch.
Heres the numbers from the plate (didnt know this was there!) –
FDF784G.R 36633270900 Type DWL-DEA602S
S/N 001262513August 25, 2012 at 9:24 pm #380136iadom
If you are 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain about that serial or SN number then the part you need is a C00274116.
The C00094128 is for a totally different machine. 😉
August 25, 2012 at 9:30 pm #380137G7MRV
Those are the numbers ive copied form the label.
Can you provide a link to the item description please? For some reason i cant seem to search on the part number, and i cant find it in the hotpoint dishwasher door parts list! (probably me being think this time of evening!)
August 25, 2012 at 9:37 pm #380138G7MRV
iadom wrote:
The C00094128 is for a totally different machine. 😉Which shows exactly why a forum like this is so useful! And why you should always check, rather than use something because it ‘looks right’ 😀
August 25, 2012 at 9:38 pm #380139iadom
It won’t be listed in our shop but if you send an e-mail to spares@ukwhitegoods.co.uk with the details it should be possible to obtain one for you.
Sent from my iPad using Tapatalk HD -
