Cost of LG bearing replacement
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Cost of LG bearing replacement
  • #75779
    knigma
    Hi, I think the bearing and bearing seal on my LG F1622GD5 Direct Drive is starting to go as the machine is making a dreadful squealing noise, sounding similar to this video:
    https://www.youtube.com/watch?v=0kWI7XLKOnU
    It looks like the parts are around 25gbp but I understand this is quite big DIY job. How much should I expect to pay in labour if I call out an engineer (I’m in Bedfordshire, UK fwiw).
    PS: Anyone found a good set of instructions or a video if I consider this as a DIY job.
    Thanks, Mark
    #396116
    Allsorts
    Re: Cost of LG bearing replacement
    First instruction would be not to carry on using it until the job is done if you think the bearings are gone, otherwise you will damage more than just the bearings and costs will spiral.
    I must say though, that does not sound like bearings to me
