could somebody help please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum could somebody help please
  • #42816
    spencezoid
    AEG-LAVAMAT OKO UPDATE L74689,SN 40861284,PNC91400245301
    i put the washer on this morning on delay timer for when i came from work, it had not washed and E40 was showing on the LED display,I have cleaned filter,and drawer out retried to wash, ,the minutes it should take show, and the when i press start pause button it just returns to E40 again,and the door no longer makes the clicking noises when start pause are pressed
    thanks in advance for any help or advice
    #275009
    helo_75
    e40 – faulty door lock
    #275010
    spencezoid
    thank you,can i buy a new lock/door and is it something i would be able to replace myself,
    #275011
    Re: could somebody help please
    THIS should be the one you need.
    Not a difficult task, remove the mains plug, slide the plastic band off the outer lip of door seal, remove the two screws holding door lock and swap over taking care to replace the wires like for like, or make sure the plug goes in the right way round.
    spencezoid
    got old one off,thank you all for your help
