Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › could you recommend me a fridge freezer?
- This topic has 4 replies, 2 voices, and was last updated 17 years, 3 months ago by
skoop.
January 10, 2009 at 3:43 pm #42459
skoop
ParticipantI need one 55cm wide or less, freezer with three shelves or more, (so doesn’t have to be huge capacity), reasonably energy efficient, reliable would be good of course!
Also good value – doesn’t need to be frost free or particularly fancy. Cheap is good if it’ll keep working.
Are there any models which spring to mind? Or makes to avoid/makes you can trust?
Thanks.
January 10, 2009 at 4:37 pm #273571skoop
ParticipantRe: could you recommend me a fridge freezer?
Just to add a bit of information – it would be a 50/50 split I am after as I actually will use and fill the freezer more than the fridge. It doesn’t have to be huge capacity overall as it is just for me.
This beko would probably be fine in capacity but I’ve know idea about that make.
http://www.dixons.co.uk/martprd/store/d … Reevoo.com
or this beko (not frost free so less likely to go wrong?) http://www.reevoo.com/reviews/mpn/beko/cda538
This bosch ( a good make for f/fs like it is for other white goods?) would possibly be ok but I don’t need as much fridge space as it has
http://www.dixons.co.uk/martprd/store/d … urce_id=aw
I’m not sure if the better makes will make the ideal size for me (in a price I can afford).
January 10, 2009 at 5:54 pm #273572skoop
Hmm, I was looking at another forum and found this surprising information…
“In my latest edition of Which? magazine, for reliability, Siemens came 1st @ 96{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}, second was…Beko, yes, Beko @95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}” (dated 13/dec/08)
moneysavingforums thread about getting a new fridge freezer !!
January 12, 2009 at 8:30 am #273573don
ModeratorRe: could you recommend me a fridge freezer?
Hi skoop
My A-Z reads and in no particular order Hotpoint RFA52P and the frost free FFA52P, Beko TDA531,CDA538,CDA539, CDA540, CDA543 and last but not least the CDA554. Bosch KGV24V01GB, and the KGV28V01. Gorenje RK4256E. Lec TF5586. Zanussi ZRB2825.
I would personally go in order with Bosch with it`s two year warranty and good build then the Hotpoint`s, after them the Gorenje, then the Zanussi followed by the Beko and bringing up the rear the Lec.
HTH
Don
January 12, 2009 at 9:26 am #273574skoop
Thanks, I have gone for the bosch.
