CPCA240FSK temp probe
  • #53666
    yorkshireracer
    I’ve fitted a new pcb to this machine. But still intermitently freezes the fridge. Presuming a new temp probe needed. I know the part is available but have heard the repair is a pain (digging into cabinet). Anybody any tips or just right it off???
    #316783
    Tubs
    Re: CPCA240FSK temp probe
    Have to say, its not too bad once you know were sensor is buried, approx 100mm down and about 50mm in from top left corner, Dont bother threading loom through, youll be there all day. Cut off duff sensor, solder and cover wires with heat shrink.
    Steve
    #316784
    loopey
    Find out the indicated position, on the
    outer back wall of the appliance (Ref. X
    in Picture 11). This is the exact centre
    of the window, to be opened next.
    Dimension H (measured from the top
    edge of cabinet): 168 mm.
    Dimension L (measured from the left
    side edge of cabinet): 172 mm.
    gimme a bell lol with yer email addy will send you pdf walk through its dead easy lol
    #316785
    yorkshireracer
    I’ve measured the spot mentioned, but no probe. Any ideas??
