Creada 48341 Cooker
  • #45674
    rocker
    One of the solar hob element heats, but unable to turn heat down via the energy regulator have changed (no different) I feel it must be the limiter at fault can anyone please confim. cheers john
    #286529
    martinm
    Re: Creada 48341 Cooker
    should turn down when you turn down the regulator, cant see it being the limiter. Maybe regulator or plate incorrect wiring?
    #286530
    rocker
    Nothing has been altered ie wiring ect, have fitted a energy regulator 40ER101C1P correct part !! (as I say no difference) can anyone please help me with this. John
    #286531
    bzz67
    limiter is only a overheat cutout. sounds like energy reg is wired wrong or maybe lost neutral to reg.
    #286532
    clivejameson
    IIRC some of these replacement regulators require an additional linkwire…some of them are supplied with the wire and mod sheet and others aren’t 😕
    #286533
    rocker
    although the regulators are different I have changed over cables number for number.
    #286534
    bzz67
    looks like the link wire has to be fitted between p1 & s1
    all other wires are number for number.
    #286535
    bzz67
    sorry ignor that last post i think thats for 48er
