creda 1000 superspeed washing M/C model 17086
Home Forums Public Support Forums Help And Support Washing Machine Help Forum creda 1000 superspeed washing M/C model 17086
  • #25611
    bobby6
    any advice how to remove / split the drum to remove foreign object?
    #206693
    Re: creda 1000 superspeed washing M/C model 17086
    We cannot give you blow by blow instructions, however the cabinet front comes off, then it should be obvious. If you do spilt the drum then due to the age of this machine you should really replace the outer drum seal, part number 168172, it is a compression seal that will almost certainly leak if you do not fit a new one.
    Don’t forget to remove the mains plug if you do proceed.
    bobby6
    many thanks Jim,
