Creda (17049) not washing clothes!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda (17049) not washing clothes!
  • #29114
    canshefixit
    Hello you helpful people!
    Having further problems with this machine, it simply isn’t doing the job.
    Clothes come out partially washed, some arn’t even wet! It did a wash cycle a few days ago and it tripped the fuse. Since then it hasn’t been washing properly, it hasn’t tripped the fuse again, but the dial appears to be clicking excessively when going through the rinse and spin cycles.
    I have tried reducing the load quantity, checked the water inlet and outlet hoses and connections and they don’t appear to be blocked. i did a prewash to check water was going in and it is.
    If anyone has any suggestions as to what could be the problem and what I need to check (and eventually fix) I’d be grateful.
    Cheers
    #221621
    Simon46
    Re: Creda (17049) not washing clothes!
    Does the drum turn?
    Regards
    Simon
    #221622
    Don’t keep trying to run the machine, it sounds as though your motor brushes have worn away. The circuit breaker or trip may have prevented further damage and if lucky you will just need a set of brushes.
    Plug out at all times when you have the lid off.
    http://tinyurl.com/2gnrog
    http://tinyurl.com/yupm39
    canshefixit
    Yes the drum turns.
    #221624
    canshefixit
    If it is the brushes, how will I know? Is this something that I can check myself or even fix myself? Is it expensive or difficult?
    I don’t want to spend a lot of time and money on this machine if it can be avoided.
    :rolls:
    #221625
    petalpop
    UNPLUG MACHINE :zap:
    you will then see the motor and brushes (see link supplied by iadom)
    if the carbon sticking out of the holder is less than 10mm
    it is probably them at fault
    #221626
    canshefixit
    I have located the carbon brushes there is some black dust, I am unable to remove them, they don’t appear to be held in with any bolts/screws etc, any tips? The motor is at the top and the brushes are on opposite sides of the centre.
    Thanks for getting me this far – sorry for being a ditz and not picking up on the links straight away!
    #221627
    If you look at the picture here, http://tinyurl.com/2gnrog you should be able to see the small barb or lug that keeps the brushes in place, at the bottom of the left hand one and on top of the right hand one. You have to depress this to slide the brushes complete with holders out of the motor.
    canshefixit
    Thank you got them out! They are both in quite a state, both carbon brushes are worn down, black, one is so worn down there is metal showing in the centre, the holders themselves appear undamaged, am off to order replacements…
    #221629
    canshefixit
    Replacement carbon brushes arrived promptly – thank you uk whitegoods.
    Seem to install simply enough – tabs unfolded to open out brushes, machine drum went round on spin cycle. Am running complete cycle. Drum does not appear to be turning during rest of cycle – any ideas? 😕
    #221630
    Most of the time if the drum will spin then it will wash. Possible causes of no wash action, loose connections to the timer dislodged whilst working on it, a faulty armature ( does the machine make a loud buzzing/humming noise when it should be washing). A faulty control unit damaged by constanlty trying the machine and blowing the fuse or tripping the RCD.
    canshefixit
    The machine doesn’t make a lound humming or buzzing noise during the cycle. I can look at the timer and it’s connections, but how would I check for a faulty control unit or faulty armature?
    Cheers
    #221632
    If it starts to spin quite smoothly and without seeming to drag then the armature is more than likely OK. Other than a quick visual check on the green, track side of the control unit for blown or lifted tracks the only way for you to check is to replace it. Unfortunately I think it would be over your budget to replace the control unit.
    canshefixit
    I’ve had a look at the timer dial, reinstalled it, tried running the machine, it no longer spins at all, just hums, guess we’re off to the laundrette…
    anyone need a fairly new door seal and or carbon brushes I’m your woman! 😥
    #221634
    petalpop
    check you have released the carbon from its holder properly
    ie lift tabs as far as they will go
