Creda 17084E DC 56163086
Viewing 15 posts - 1 through 15 (of 17 total)
  • #19708
    Alanj
    Hi Guys,
    has anyone out there got wiring diagrams for the above appliance?
    A copy would be most helpful.
    Alan
    #184198
    Alanj
    Re: Creda 17084E DC 56163086
    If anyone has a wiring diagram, it’s the connection diagram for the pressure switch I am looking for.
    Alan
    #184199
    I don’t have a Creda manual but as this is a Hotpoint clone, we could possibly narrow it down to a similar Hotpoint model if you can give me the wiring colours, pressure switch terminal numbers and the destination of the wires from the pressure switch.
    Alanj
    Hi iadom,
    It,s a 2 level P/switch with 8 wires,as follows
    Red – p/sw to hot valve
    purple /grn – p/sw to heater
    red/grn – p/sw to door/sw
    blu – p/sw to 3way cold valve
    black ps eleven – p/sw to timer edge con 8
    white one – p/sw to timer edge con 5
    white two – p/sw to timer edge con 7
    white four – p/sw to timer edge con 6
    red/gn and white one are piggybacked on p/sw
    p/sw connections 11,12,14, 31,32,34,36.
    hope this is helpful.
    Alan
    #184201
    Unfortunately none of the WM ones I have a remotely like that I’m afraid.
    I went to a 17087 today and made a note of the P/SW wiring just in case bit it was nothing like that. 😥
    Also Partfinder lists pressure switch as a 3 level which I would expect with all those connections although the numbers you give don’t tie up with a 3 level switch. 😕
    I have made an enquiry to a contact who is going to have a look through his collection. 😉
    #184202
    Dave_Conway
    Here’s the Hotpoint model the pressure switch is fitted to if anyone has the info:
    9529A, 9529P, 9529W, 9539A, 9539P, 9539W, 9549A, 9549P, 9549W, 9777P, WM23A, WM23P, WM23W, WM26A, WM26P, WM26W, WM31A, WM31P, WM31W, WM32A, WM32P, WM32W, WM35A, WM35P, WM35W
    Part number 1600856.
    It’s actually a 3 level (the 3rd being the silent touch contact for flood protection – this will be terminal 36).
    The other two levels will be:
    Level 1 – common = 11 – 12 and 14 will be n/o and n/c
    Level 2 – common = 31 – 32 and 34 n/o and n/c etc.
    That may help a bit ?
    #184203
    Numbers don’t match the WM31/32/35 manuals Dave.
    The numbers in the Hotpoint manual for those are the usual 11.12.14-21.22.24 & 31.32.34 No #36?
    Also checked the manuals for 9529/9539/9549 & 9777 they are all the earlier timer with module clipped at the rear.or side of timer, not the hybrid timer.
    Just thinking about this I have fitted the odd pressure switch to this range although not very often. I seem to remember that the replacement pressure switch was a later type that included a few wiring mods, perhaps this machine has the later switch fitted as standard.?
    Unfortunately I don’t have the details of the modifications to hand. 😥
    #184205
    Alanj
    Hi Guys,
    if this helps the timer is a 904 2425 02.
    Alan
    #184206
    Dave_Conway
    iadom wrote:I seem to remember that the replacement pressure switch was a later type that included a few wiring mods, perhaps this machine has the later switch fitted as standard.
    Yeah, sorry, the pressure switch is only fitted to later models with the hybrid timer unit.
    Order a pressure switch, it may come with the diagram as part of the mod 😉
    #184207
    Alanj wrote:Hi Guys,
    Alan
    Not really Alan, that timer or its replacements fit well over 30 different models.
    #184208
    Dave_Conway
    does anyone have a copy of the wiring diagram that is packaged with the above pressure switch, or a copy of a Creda 17084E manual.
    Alan
    Copied here to keep things tidy 😉
    #184209
    HotDog
    Copy of manual on its way to iadom 😉
    #184210
    Fantastic Cliff, if you make it to the September meeting I owe you a pint. 😆
    Alanj
    Is there no ex Hotpoint engineer with this info out there?
    Alan
