Creda 37445 No heat
  • #55823
    stamm
    I have a Creda 37445 which has no heat at all.
    I have checked the heating elements & they are ok.
    Apparently there are 2 thermal cutouts on the rear just above the heater elements, should these have continuity or how can they be checked?
    Are there any more cutouts or anything else I should check?
    If they are faulty what is the part no. & cost of the spares.
    Regards
    Roy
    #325248
    Re: Creda 37445 No heat
    There are not two thermal cut outs. One is a one shot thermal cut out, the other is the temperature control, cycling thermostat. 😉
    Usually the one shot will have tripped, a simple continuity test is all that is needed, they should both be closed circuit.
    THESE are what you need.
    There is another stat or stats hidden away inside fixed to the vent but they don’t often fail.
    PS. Take great care not to press the bases of the new stats.
