Creda 37642 (Reverse air) Not turning off
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda 37642 (Reverse air) Not turning off
  • #52616
    VanHalensArmpit
    Hi folks…
    As above, a Creda 37642 reverse air not turning off after a cycle on the timer.
    Ive checked the heater, stats, door latch too and all seems ok. I disconnected the timer and reconnected and she stopped first time i tried but alas, on the next couple times she just ran on. .
    Im assuming it is the timer but could this also point to a stat problem?
    Im sorry if this has been covered before here but i did a search to no avail =)
    Thanks for any help you great people can provide!!
    #312492
    Re: Creda 37642 (Reverse air) Not turning off
    Almost certainly a timer fault, possibly damaged internal contacts.
    Part number is 1700938, around £43 ex vat though.
    #312493
    VanHalensArmpit
    Thanks a lot for the response! Yea, as soon as she stopped the first time and then wouldn’t again I thought it was pretty much the timer. Just wasnt sure whether it was a common problem for this older model.
    Thanks again Iadom =)
