Re: creda 37654g
You might be struggling, same timer is used in the Hotpoint TL64 & TL71 although the latter one also has a delay timer.
No part number for manual on Partfinder and the user handbook is also listed as obsolete.
I don’t have one but if anyone has a Hotpoint TL64 wiring diagram you should be able to work it out from that.
EDIT. Just found a copy of the Creda 37753E on my HD. That also uses the same timer, will send you a copy it may do the trick. 🙂
