Jim, Check the tub stat behind the heater as can find one side O/C. Its a manuel reset but you have to take cover off to do so. I have had a few and its been down to blocked lower spray arm.
Turned out to be classic D/W fault. Harness broken where it bends at the door. To badly damaged to affect a repair, doesn’t look as though new loom is available. 😥
