Creda 47917
  • #54237
    ray.t
    Been to this today, it wont heat.
    I removed lower inspection cover and checked the heater and stat that I could see, both are ok.
    I then removed the door trim to check wires etc and there is a stat next to the dispenser that is O/C.
    Would it be a good idea to change both stats on this model or can I just change the one that has gone?
    Ray
    #318937
    Re: Creda 47917
    ray.t wrote:I then removed the door trim to check wires etc and there is a stat next to the dispenser that is O/C.
    I’m not familiar with this dishwasher as to the exact function of the stat in the door but suspect it is an overheat protection device? In which case just temporarily shorting it out would no doubt prove that heat has been re-established and that the door stat is faulty? 😕
    #318938
    ray.t
    Re: Creda 47917
    Thanks Martin.
    I am not familiar with this model either.
    I did think to just short it out to test it but if the other stat is faulty would it not cause a new stat to go again?
    Cheers
    Ray
