CREDA 48145 double electric oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CREDA 48145 double electric oven
  • #25218
    cornflakes
    I fitted a new gen electronic timer in early january
    client has just contacted me,, they suffered 2 quick power cuts this morning
    since then the you can not set timer unit,,clock flashes dashes and AUTO
    by press combination of buttons as per manual..nothing moves or indeed does any button fuction
    I have suggested a de power overnight, not sure if there is a capacitor supply internally..will revisit via phone wednesday
    any other ideas of help welcome.. I hope timer is not shot it ( expensive or what) because of voltage surge. surley it should be protected from such variation of supply
    regards
    Graham
    #204961
    cornflakes
    Re: CREDA 48145 double electric oven
    de-power made no difference to fault
    any ideas welcome
    #204962
    maltheviking
    Sadly it sounds like it’s damaged, 😥 you could try QER etc they might be able to repair
    Mal
    #204963
    Bryan
    cornflakes wrote:I fitted a new gen electronic timer in early january
    Perhaps it`s an idea to get your customer to contact their electricity supplier or who ever was responsible for the power cuts/surges.
    Sure your customer would have a strong case for recompense if there was a known problem with the supply at the time.It`s not totally uncommon for electronics to fail under these circumstances.
    HTH
    Bryan
    #204964
    maltheviking
    HTH
    Bryan
    Hi Bryan
    In our area the supply company have an added clause to thier contracts saying that they will not be responsible for any domestic appliance failure 😥 and they stick to it.
    I had three customers with failed compressors on their fridges, all the same type(Candy) and in the same area all from the same power cut. I even gave them each others names so they could have a collective “go” and a report from me. The supply company just laughed at them, must have good lawers 😥
    #204965
    cornflakes
    was expecting the worst
    surely Creda should have some form of built in protection for power surges on electronic kit like this, after all it was not cheap even at trade price.
    what do you think creda’s response might be
    #204966
    mike412
    Just a thought but would this situation not be covered by the customers contents insurance?.
    Mike.
    #204967
    jeremy
    tricky situation this but if push comes to shove at the end of the day its not your fault, the timer has failed due to external factors outside of your control most ppl would see this if explained. Have to say that our leccy company gives a 50 quid gesture of goodwill with no future comeback under power surges/spikes. i have had a few customers get this.
    #204968
    Dave_Conway
    This one’s down to the customer to sort to be honest, it’s neither Creda’s or your fault this has happened.
    As mentioned it’s a delicate situation but I wouldn’t be left out of pocket over this. The supply is to the customer’s house, their problem to resolve and take the power supplier to task over it 😉
